Intake............
Talk about or show off your custom modifications.
Silverfox
Intake............
Postby Silverfox » September 8th, 2012, 8:24 am
Has anyone taken the air cleaner off and used a k&n filter to replace it???
Jeff...............Just Ride..............Blessed
Mort
Re: Intake............
Postby Mort » September 8th, 2012, 12:08 pm
What a novel idea. You mean take the factory air filter off and replace it with a filter from K&N? Do you have to rejet or reprogram the bike for that mod?
Silverfox
Postby Silverfox » September 8th, 2012, 7:00 pm
Yes I believe you would have to rejet, reason being you would have more air going in and maybe leaning out the gas/air mixture........I hope others read this, they may have ideas on the jets or mapping..........
Jeff.......Just Ride.................Blessed
Postby Elephant Rider » September 9th, 2012, 12:12 am
There is some stuff here on this forum about a rejet for a K&N. I still have the filter but I haven't put it on yet. Just haven't gotten around to doing it.
What I could find relatively quickly. I'm sure there is more, but I think this is all you need.
http://volusiaowners.com/viewtopic.php?f=4&t=3674
4th post down, click on those 2 links.
Mort
Postby Mort » September 10th, 2012, 6:34 am
Most would say, go K&N without changing to a more free-flowing exhaust system would not require a jet or retune change. This is because you have more air going in, but the same as stock going out, therefore you are not breathing any better than stock. Or you can get a tuner for the C50 and get 2 HP or so more with the K&N. But the K&N is a PITA to stuff into the OEM stock aircleaner housing.
Postby Elephant Rider » September 10th, 2012, 12:53 pm
Mort wrote:But the K&N is a PITA to stuff into the OEM stock aircleaner housing.
This is true.
Silverfox
Postby Silverfox » September 10th, 2012, 6:57 pm
The air cleaner would be removed, the pod mounted directly to the carb..........
Jeff....................Just Ride.................Blessed
v0lusia
Postby v0lusia » September 11th, 2012, 7:07 am
Silverfox wrote:The air cleaner would be removed, the pod mounted directly to the carb..........
Most people that have done this have done it with a Unifilter up under the tank rather than a K&N. You can try search terms like"Unifilter" and/or "Naked jugs" <-- remove air filter and PAIR valve, to find more info. I am pretty sure there is a detailed how-to here or on the VR site for doing it.
-Metal monsters that let us breathe. Let us smell. Keep us from being numb. - Zookoff
-Twisties give me happy pants
Here's to a long life and a merry one.
A quick death and an easy one.
A pretty girl and an honest one.
A cold pint-- and another one!
Cobra
Postby Cobra » September 11th, 2012, 4:06 pm
I just posted a cool one up for sale if your interested check it out.
Return to “My Custom Mods”
Users browsing this forum: No registered users and 4 guests
