adjusting idle
htlong
adjusting idle
Postby htlong » February 14th, 2013, 5:56 am
I just had my valves adjusted on my 05 c-50, and now I cant adjust my idle ,I adjust it and when I ride it increases and sometimes when I slow down the idle slow also? what did I goof up? :shock:
htlong
Re: adjusting idle
Postby htlong » June 7th, 2013, 5:43 am
I have cleaned the injectors ,replaced a pressure valve,it idles great until it warms up and then it drops to a stall or near stall , the bike runs great until I stop for a red light and then I have to keep goosing the engine until the light turns green does anyone have any ideas what could cause this?
Re: adjusting idle
Postby Doc » June 7th, 2013, 11:39 am
I had a very similar problem.. mine turned out to be a bad injector.
htlong
Re: adjusting idle
Postby htlong » June 13th, 2013, 5:46 am
the shop I took it to cleaned all of the injectors and they worked perfect they were waiting for a factory rep to help.....6 weeks later I had to return north .
after I got the bike back it runs great and idles perfect until it warms up then I have to be constantly reeving the engine at a red light ,I feel like I am a 20 year old reeving to be cool!
htlong
Re: adjusting idle
Postby htlong » September 27th, 2013, 5:29 am
the throttle body gasket was leaking from when the valves were adjusted [CLAP]
