Apes on the Street Glide
Want to talk about motorcycles that you own that aren't a C50 or a Volusia? Here's the spot for that.
LabRat
Sergeant-at-Arms
Postby LabRat » October 18th, 2011, 6:58 pm
Wrench wrote:Looks good Doc, nice job!
ditto
'05 C50 Aug 05 - Sept 07
'08 FLHTCUSE3 - Sept 07 - Oct 13
'14 Indian Chieftain - Oct 13 - ??
Wrench
Re: Apes on the Street Glide
Postby Wrench » October 18th, 2011, 8:32 pm
Yeah, it looks like our techno-geek is a gearhead too! WHO KNEW??? :shock:
Rob
Postby Rob » October 18th, 2011, 9:13 pm
Wrench wrote:Yeah, it looks like our techno-geek is a gearhead too! WHO KNEW??? :shock:
Yep, it's true. Doc has some SERIOUS wrenching skills for sure.
I'm not sure I'm up for this mod. I'd probably wind up with a half-ton of motorcyle on top of me! :lol:
I'd better check my life insurance before I try it!
2014 black & chrome HD ultra, 12" mini-apes, 4" Rinehart Racing exhaust, BSEG!!
2003 black & chrome Suzuki Volusia
Metal monsters that let us breathe... -- Zook, a well-remembered VOL Original
Re: Re: Apes on the Street Glide
Postby Doc » October 19th, 2011, 6:30 pm
Doc wrote:
The Volusianator wrote:But do you like the way it turned out? Do you still like the feel and ride?
Doc wrote:Got it done. All I gotta say is.. Pain in the ASS!
Still don't have the clutch cable adjusted where I think it should be. Thinking I have to take the transmission cover off again and check the "ball and ramp" assembly to make sure it's sitting correctly.
Got the clutch sorted out.. Pulled the tranny cover and checked the ball and ramp.. Sure enough.. One of the bearings had slipped into the slot of another bearing. I fixed it and reassembled. Clutch works like a charm now :)
Rob
Postby Rob » November 5th, 2011, 6:30 pm
Finally talked with the dealer about this mod today...they said the price for parts alone is $667 and I probably don't want to know how much the labor charge will be!
ABS is not an issue, but apparently I'll have to give up my beloved heated grips? Damn!
Postby Doc » November 5th, 2011, 7:22 pm
No.. You should be able to keep heated grips.. Did they say why?
Rob
Postby Rob » November 5th, 2011, 9:29 pm
No explanation given. The guy was just going by the book, tho. I'm gonna get a second opinion for sure cuz I am really attached to the heated grips!
LabRat
Sergeant-at-Arms
Postby LabRat » November 6th, 2011, 7:27 am
That sounds odd. Are you running HD grips? If you are and still can't do it, check out heat demons. I'm sure you can with those and they work better.
Rob
Postby Rob » November 6th, 2011, 2:28 pm
LabRat wrote:That sounds odd. Are you running HD grips? If you are and still can't do it, check out heat demons. I'm sure you can with those and they work better.
Yep, currently using HD grips, which will fry your hands anywhere above 2.5 or so on the thermostat! Will definitely check out the heat demons, tho, thanks for the tip!
LabRat
Sergeant-at-Arms
Postby LabRat » November 6th, 2011, 7:38 pm
I'm on my third set of HD heated grips. They were standard on my bike and were replaced under warranty. If they go out again, definitively going with heat demons. A lot of the guys on the CVO site switched to them after their grips kept failing.
Return to “Other Brands”
Users browsing this forum: No registered users and 1 guest
